Anyone seen this?
When trying to connect MSOffice to Windchill, I get the LDAP authentication login, and then upon login I get an error message stating that the server is unreachable. This happens with any conction to Windchill; from a MS product, registering a server in Creo, and through the windows explorer. I can ping the server and login just fine through any external browser. See screenshots. I have a call logged with PTC, but they have been unable to figure it out yet.
Thanks for the help!
Terry
About the Preference Management Utility.
Darren
I had some issues at first too. If you don't set the download mechanism to desktop integration, you will see the errors that you are getting or something similar. The comment about adding the site to the approved or trusted sites list is also necessary in order touse the integrated check in feature. I hope this helps.
