Display order of multi valued String attribute.
pyalavarthi
Hello everyone,
We are using PDMLink 10.1 M020. We have a multi valued String IBA ,
named *building. *No matter what order we select in the create wizard, it
is always displaying in sorted order in Info page. This is causing issue
for us as the value is related with another attribute and order messes up
the relation between the two attributes. I am wondering if there is a way
to display the values in un-sorted order. Any suggestions or pointers would
help.
[image: Inline image 1]
Prathap <">http://goo.gl/LuT5>
What does jcaDebug=true and jsDebug=true tell you? Probably functionality
of a sorting algorithm in the default data utility or delegate. May need to
customize your own and register it.
We were told it is not possible to change this logic. When we converted our 9.1 customizations
