All,
I have a need/want for setting up a drop down menu or radio buttons (either one would work) for an activity. I have 6 workflow variables that a user is going to update. Each of them have 3 options to choose from, they are the same three options for each variable. I want to have those options pre-defined so that the user doesn't have to type them in (save on the confusion for the users). For a little better understanding of what I'm looking for, here is a quick example of what I'm looking for:
Variable 1: *Options* 0, 1, or 2
Variable 2: *Options* 0, 1, or 2
Variable 3: *Options* 0, 1, or 2
Variable 4: *Options* 0, 1, or 2
Variable 5: *Options* 0, 1, or 2
Variable 6: *Options* 0, 1, or 2
Is there a way to set up a configuration to allow for this or is this something that would require a customization. This is something different than what I've done before. I know that I have seen the drop down appear for the Define Team task or for WT.Team.Team variables. If anyone knows how to tap into something like that to accomplish this, I would greatly appreciate it.
Mike
Try putting your values in a resource bundle, then use that as your variable type
I think you can just extend EnumeratedType. I have the same requirement today so I'm going to see if that works.
I don't have any experience working with a resource bundle or enumerated type. Can you elaborate a little bit more on them as to how I would go about creating them?
Create your .rbInfo in the same src package.
wc shell: ResourceBuild com.mypackage.*
If you run into any problems with ResourceBuild, make sure your .rbinfo is in the wc src folder.
My class is named EnhancementType, so my rbinfo is named EnhancementTypeRB.rbInfo. I'm not concerned with localization now.
Hello Matthew,
I tried doing similar thing in Windchill10M020.
As I am newbie to customization don't know how to define and call the enumeration in rbinfo file as workflow variable.
Kindly request you to send me the steps.
Thanks & Regards,
Birendra
rbinfo files get compiled into class files. For instance, wt/project/RoleRB.rbInfo gets compiled into wt.project.Role. In the class dropdown of the Create Variable interface for your workflow template/activity, you should be able to select "wt.project.Role" from the list or type it in yourself as an "other class."
Hi Mike,
I have similar requirement, Will like to know whether you were successfull in achieving drop down for tha workflow variable ?
Birendra
