Version: Windchill 12.1
Use Case: Is there a method to track the deletion history of effectivity in WTPart? For instance, if I have a WTPart A and initially set 'xyz' as its effectivity, but later someone deletes this effectivity and either sets a new one or leaves it empty, is there a way to identify who performed the deletion? Thank you, Pravin
Description:
Useful article - "API to retrieve associated Effectivities of a WTPart in Windchill PDMLink": https://www.ptc.com/en/support/article/CS152894
Hi @PS_10220246 ,
If so, please mark the appropriate reply as the Accepted Solution or please feel free to detail in a reply what has helped you and mark it as the Accepted Solution. It will help other members who may have the same question.
Best regards,
