Error running WTPartCreator
I'm posting on the off chance that someone else has encountered this and has a fix. I am trying to get the WTPartCreator tool to work. I have it so that just one object is being processed before moving on to bigger chucks of data. No matter what object number I choose, it will not create a wtPart and if I already have the wtPart in the database it will not connect the two.
The error that I get is:
(wt.series.seriesResource/2) wt.series.SeriesException: The revision value is not valid within the series: 1, series=Default
Nested exception is: The revision value is not valid within the series: 1, series=Default
Anyone run across this before and have a solution?
Thank you
