Error when loading global enumerations using load from file
RK_10805837
I am trying to load global enumerations from windchill 11.1 to windchill 12.0 using Load from file command. However, I am facing an an uniqueness exception in doing so. The windchill version for the target system is 12.0.2.15 with CPS15 installed. I have attached the log file containing the error. Kindly provide any suggestions on how to resolve this,
Command used:-
windchill --javaargs="-Dwt.auth.trustedAuth.username=wcadmin" wt.load.LoadFromFile -d /appl/ptc/builds/SCF_Lufkin_Build/loadFiles/sic/GlobalEnumerations/Global_Enum_All_0.xml
Ramsha
12 REPLIES 12
Hi @RK_10805837
Your source file contains some global enum values that are not unique as it is needed in the database.
You need to find what value is not unique.
PetrH
Hi @HelesicPetr ,
A colleague of mine has used the same source file to load into his local windchill and it seems to be working fine for him. I guess this is a database issue not related to the loader file. Could you please provide any hints on how to resolve that?
Thanks again,
Ramsha
Hi @RK_10805837
It is possible.
The point is that the system can already contains some values that has to be unique and yours are just duplicated.
One record is not unique and you need to find what it is.
Go to database and check the table LWCLocalizablePropertyValue
select * from wcuser.LWCLocalizablePropertyValue
compare the values to your file
add a where condition
where idA2A2='5422'
also you can divide your file and try to load one enumeration by one , and thanks that you can find what is wrong.
PetrH
PS> if you can share a source file, it can be useful.
Fadel
(To:RK_10805837)
Windchill complains about below entry in DB
LWCLocalizablePropertyValue:5422
you can import the attached qml on the target system and run it with the given id 5422, it should then give better sight in the problematic entry in DB
Fede
Hi @Fadel ,
Thankyou for your response. I tried importing your attached qml on the target system but I am facing the below error:
Is there something wrong that I am doing?
Fadel
(To:RK_10805837)
import as QMl not as template
Fede
HelesicPetr
22-Sapphire I
(To:Fadel)
@Fadel
the ootb record with that number is 'Update Stamp' 😄
PetrH
Fadel
(To:HelesicPetr)
The IDA2A2 are different from a system to the other on my VM they are 69xx
Fede
HelesicPetr
22-Sapphire I
(To:Fadel)
Hi @Fadel
Yes but it is very low ida2a2 number so I guess that the record is from installation so it is the OOTB enumeration record.
if the source file contains the OOTB enumeration then it could case this problem.
PetrH
Fadel
(To:HelesicPetr)
after 12 years windchill, the ida2a2 is still a mystery to me , wcadmin is actually one one of the first objects that are  created and it has ida2a2=2008 , on other VMs it has ida2a2=11 .
Fede
Hi @Fadel ,
Whenever I execute the load command, the value at which the error is pointing is always different. Moreover, when I try to search for the  same value in the report, it doesnt show me any results
Fadel
(To:RK_10805837)
Do the given numbers exist in the xml file you try to load ? can you share a copy of that file ?
Fede
