I'm trying to reuse a QML from cs103435.
I saved the file locally as .qml (without the header) and followed the instructions from CS256736 to upload it into the report templates.
I get this:
What am I missing?
Right-click the link and select "Save link as"
This is for Chrome. The option to save might look different on other browsers, but should function the same.
I just downloaded the QML from the article and loaded it into my test system (12.0.2.X) without any problems
Did you do is as is? What I did was copy the content into a new document and saved it as a .qml.
Below are a couple of articles that explain how you can load QML reports into Windchill
How to load QML reports into Windchill
How to load a report exported as QML from the command line
I did the upload through the Windchill interface bit. @joe_morton's method worked. What I don't understand still is why that works and why saving the content as a .qml doesn't when the content of the document is exactly the same.
Be that as it may, thanks for the help!
