Error when uploading a QML
Dobi
I'm trying to reuse a QML from cs103435.
I saved the file locally as .qml (without the header) and followed the instructions from CS256736 to upload it into the report templates.
I get this:
What am I missing?
Right-click the link and select "Save link as"
This is for Chrome. The option to save might look different on other browsers, but should function the same.
5 REPLIES 5
Marco_Tosin
(To:Dobi)
I just downloaded the QML from the article and loaded it into my test system (12.0.2.X) without any problems
Marco
Dobi
(To:Marco_Tosin)
Did you do is as is? What I did was copy the content into a new document and saved it as a .qml.
Marco_Tosin
(To:Dobi)
Below are a couple of articles that explain how you can load QML reports into Windchill
How to import QML into Report Management in Windchill PDMLink
How to load QML reports into Windchill
How to load a report exported as QML from the command line
Marco
Dobi
(To:Marco_Tosin)
I did the upload through the Windchill interface bit. @joe_morton's method worked. What I don't understand still is why that works and why saving the content as a .qml doesn't when the content of the document is exactly the same.
Be that as it may, thanks for the help!
