Hi
I am new to windchill so sorry if this is an easy problem to solve. When I try to file drw files into a context in windchill I get this error message "Filename has been renamed in commonspace, please perform Workspace Synchronisation" I have performed a workspace sync and I have tried a new workspace and various different drw files but still get the same error message. Any help would be appreciated, my support says that there is a patch that will sort this porblem out.
Hi Chris,
I have exactly the same problem as you, did you find a way to solve/workaround it?
Best regards.
Erik
Hi
Does anyone solve this problem?
Kind regards.
Gamze
What version of Windchill and Pro/E are you using? There were some known issues in 9.1 regarding this error that were fixed in later builds. See SPR 1810938 for more information.
Hi Lori,
I am using Windchill PDM Essentials 10.1 and Creo parametric 2.0. I perform synchronisation on workspace. But it is useless. My assembly has family table. When i delete instance assembly, the problem disappear and i can check in this assembly. The instance assembly seems an incomplete instance CAD document on workspace. I verified it and it seems succeses. But it still can not be check in.
Do you have any suggestion?
Kind regards.
Gamze
