Get Folder from WCTypeInstanceIdentifier
VasiliyRepecki
Hi.
I have WCTypeInstanceIdentifier with String representation as "WCTYPE|wt.folder.SubFolder~~WCP|317820|5".
How can i get folder from this object?
Thanks.
Hi!
If 317820 is idA2A2 field in the table that describe subfolder attributes (may be SubFolder table), then you can get object like this:
SubFolder sf =(SubFolder)( new ReferenceFactory()).getReference("OR:wt.folder.SubFolder:317820").getObject();
Hi!
To get the "OR:wt.folder.SubFolder:317820" String out of the WCTypeInstanceIdentifier (Assuming your WCTypeInstanceIdentifier is stored in a variable called "tii"):
String persistenceIdentifier = tii.getPersistenceIdentifier();
WTReference reference = new ReferenceFactory().getReference(persistenceIdentifier);
SubFolder sf = (SubFolder) reference.getObject();
