In order to remove unreferenced files from the vault wanted to set the wt.fv.purgeUnreferencedFilesOlderThan =2
I just did the following steps as initial step for removing the .unreferenced files:
1) Updated site.xconf to set wt.fv.purgeUnreferencedFilesOlderThan =2
2) Ran xconfmanager –p from Windchill home directory
3) No error reported
4) Stopped Windchill
5) Cleared tomcat instances
6) After that tried to start the method server but it’s not starting
Getting following error
Exception in thread "main" java.lang.reflect.InvocationTargetException
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:597)
at wt.manager.ServerLauncher.startServerReturningProcess(ServerLauncher.java:143)
at wt.manager.ServerLauncher.startServer(ServerLauncher.java:101)
at wt.manager.ServerLauncher.main(ServerLauncher.java:472)
Caused by: java.lang.IllegalArgumentException: Empty command
at java.lang.Runtime.exec(Runtime.java:425)
at java.lang.Runtime.exec(Runtime.java:369)
at wt.manager.ServerLauncher.launchCmd(ServerLauncher.java:236)
at wt.manager.ServerLauncher.launchCmd(ServerLauncher.java:208)
at wt.manager.ServerLauncher.launchCmd(ServerLauncher.java:192)
at wt.manager.BaseServerLauncher.launch(BaseServerLauncher.java:249)
at wt.manager.BaseServerLauncher.launch(BaseServerLauncher.java:122)
... 7 more
Any idea why this error is showing up? Please let me know currently our prod servers are not starting.
Make sure the value of wt.manager.cmd.ServerManager or wt.manager.cmd.MethodServer propoertis are correct in wt.properties. If it is a unix system, make wt.manager.cmd.executor is set to blank
Binesh
Barry Wehmiller
Binesh
Barry Wehmiller
hanks a lot!! You had saved my day. That worked. As you had mentioned the properties were not set properly in wt.properties. But I didn’t change those attributes just modified the attribute swt.fv.purgeUnreferencedFilesOlderThan =2 and ran xconfmanager –p from Windchill home directory. Then how did those attributes get updated?
Thanks a lot!! You saved my day. That worked. As you had mentioned the properties were not set properly in wt.properties. But I didn’t change those attributes just modified the attribute swt.fv.purgeUnreferencedFilesOlderThan =2 and ran xconfmanager –p from Windchill home directory. Then how did those attributes get updated?
My best guess would be a bad/wrong syntax in site.xconf. So when you ran the propagation command, it altered the value of those properties. Probably a diff between the site.xconf and versioned xconf backfile from xconf-backup directory would shed some light.
Binesh Kumar
Barry Wehmiller International
Thanks for the details. I will compare the files.
