Community Tip - Did you get an answer that solved your problem? Please mark it as an Accepted Solution so others with the same problem can find the answer easily.
X
Hi All, I am wondering if anyone has a back up of their global registry file ( psi_iir.xml) for PDMLink/ProjectLink 9.1 build. We lost our installation files and I am trying to recreate them. There are no files in our Windchill/installer/instreg or user profile directories.
