Hide Secondary Attachments
DKWc
Version: Windchill 12.0
Use Case: To hide secondary attachments for specific role
Description:
Hi Team,
How we can hide secondary attachments from content table depending on roles.
avillanueva
23-Emerald I
(To:DKWc)
It would most likely be done via a customization by adding and registering a filter. That filter code would contain your business rules to block that table based on your roles.
Hello @DKWc
It looks like you have a response from a community member. If it  helped you solve your question please mark the appropriate reply as the Accepted Solution. Or if you found a solution yourselves, please document it in your topic and mark it as accepted solution. It will surely help other users who may have a similar question.
Community Moderation Team.
