Hello Experts,
I would like to create ~ 100 attributes which are of different datatypes in attribute manager is their a way to crete it at a faster rate
Athmanand
I found out the article CS59960, hence marking this question to as answered
I've done this multiple times. Prepare a spreadsheet (Excel) with all attribute info, convert it to xml within Excel, using xml definition as needed for Windchill, then upload the xml using LoadFromFile from a Windchill shell.
Hi Mike,
Thanks for your reply
Can you give me an example of the format that I need to use for LoadFromFile option ? I have used this for mass upload of documents but wondering should be the format to create and upload attributes with units
Let's take an example :
Attribute | Unit of measurement |
Y01 | N/mm2 |
Y02 | W |
Y03 | N |
Y04 | W/m-K |
What is the format that I need to use for this ?
Athmanand
I have a spreadsheet example w/a few hundred attributes used for a client - would have to scrub the proprietary data.
Would you be willing to throw a few bucks my way for it?
Nope, I can't
