How can I create mass attributes ( IBA'S) for a WT part in Attribute manager
Anand
Hello Experts,
I would like to create ~ 100 attributes which are of different datatypes in attribute manager is their a way to crete it at a faster rate
Athmanand
Anand
(To:Anand)
I found out the article CS59960, hence marking this question to as answered
5 REPLIES 5
MikeLockwood
22-Sapphire I
(To:Anand)
I've done this multiple times.  Prepare a spreadsheet (Excel) with all attribute info, convert it to xml within Excel, using xml definition as needed for Windchill, then upload the xml using LoadFromFile from a Windchill shell.
Anand
(To:MikeLockwood)
Hi Mike,
Thanks for your reply
Can you give me an example of the format that I need to use for LoadFromFile option ? I have used this for mass upload of documents but wondering should be the format to create and upload attributes with units
Let's take an example :
AttributeUnit of measurement
Y01N/mm2
Y02W
Y03N
Y04W/m-K
What is the format that I need to use for this ?
Athmanand
MikeLockwood
22-Sapphire I
(To:Anand)
I have a spreadsheet example w/a few hundred attributes used for a client - would have to scrub the proprietary data.
Would you be willing to throw a few bucks my way for it?
Anand
(To:MikeLockwood)
Nope, I can't
Anand
(To:Anand)
