How is Publishing & Watermarking in 10.2.M020 ?
rsamudrala
Hi All,
In our experience with Publishing and Watermarking with Windchill 9.1,
      • Publishing works around 60-70% of the time. This casues significant delays as watermarking can only happen after publishing.
      • Sometimes PDF is not watermarked so it should not be visible to open from the search result.
      • User must go through multiple steps/clicks to open the properties page of the document, then launch CreoView and wait for a visual representation of the PDF to be published with watermark applied.
      • The cycle time to get watermarked documents for large design document sets is very high
      • Users are faced with significant delays having to go through the above process to get a single watermarked document.
We are setting up a project to Upgrade from 9.1 to 10.2 M020, I was looking for comments on Publishing/Watermarking improvements. How Systems/Adminstrators/users are experienceing with new release.
Are there any other tools for publishing and watermarking in use other then PTC Creo View Adapter for PDF,Creo View PDF & Creo View PDF Watermaker Review.
Our goal is to improve our publishing success rate to close 100%. Possibiliy
Raghuram
TomU
(To:rsamudrala)
Have you identified why 30% - 40% of your publishing jobs are failing? We virtually never have one fail....
LoriSood
23-Emerald I
(To:rsamudrala)
It would certainly be helpful to know why so many jobs are failing to publish.
With regards to watermarks on PDFs there have been some changes with how that is handled between the older adapters and the newer ones. Please refer to https://www.ptc.com/appserver/cs/view/solution.jsp?n=CS108621 for further information.
