How to Modify Default Units
WW_8137044
7-Bedrock
How to Modify Default Units From OHM to OHM(DCR).
Thanks.
This reply is from Akim in Shanghai.
Would you please refer below article try change to the Default Unit for your system ?
How to add custom Unit or hide OOTB "default unit" for WTParts in Windchill PDMLink
Are you looking to change the display name? Or are you defining a new unit?  If the latter, you can create a new unit with that name.
