Hello Windchill,
How to batch modify user information? For example, password, email address...
I haven't found any similar actions on the interface...
-Zhangyue
Hi @YZ_10818805 ,
Windchill does not have these features.
You can try exporting LDIF file from WDS, modifying it in the LDIF file, and then importing the LDIF file into WDS.
In my opinion, these operations are also quite troublesome, so it's better to operate them on the WDS UI.
Hi @YZ_10818805 ,
thanks
I will try it out
Hi @YZ_10818805
Try to get some help from OpenDJ community.
Usually you need to do mass changes directly in the directory server does not matter which one 😄
here is example with OpenLDAP How To Change Account Passwords on an OpenLDAP Server
PetrH
Thank you, it's a great resource.
