How to check recently accessed projects by users in windchill 13,2 as a ADMINISTRATOR
Same question - "Track who logged in as wcadmin": https://community.ptc.com/t5/Windchill/Track-who-logged-in-as-wcadmin/td-p/635724
@VladimirN is correct if we want to know who used wcadmin and that generally applies for any non-user account or shared account. You can only trace back to IP address. However, there is another way to read this question. As the admin, how can we see the recently accessed list of projects by user? So we are looking for the data on which projects are being accessed and by whom. Is that correct @HK_10893644? That is stored in RECENTUPDATE table:
https://www.ptc.com/en/support/article/CS74782?source=search
This table can be accessed via QueryBuilder and a report can be generated for it.
Also look into Security Audit Reporting: https://support.ptc.com/help/wnc/r12.1.1.0/en/index.html#page/Windchill_Help_Center/auditadmin/AuditAdminSecAuditReportAbout.html
You would likely need to correlate that with the access logs if you were trying to do a forensic audit to find out what IP addresses logged in as the administrator (if using a generic account).
