Hello everyone:
Because there are a lot of unreference files exist in filevault,they occupy much space.Generally,I remove these unreference files manually.I want to know how to configure filevault remove unreference files automatically?
Thanks a lot.
It's a pity that no one knows how to configure filevault remove unreference files automatically,I am waiting for any response.
3Q.
Hi there,
I wish this function would exist, but obviously it doesn't.
But there is a tool, which you can run from a windchill shell:
java wt.fv.ReplicaCleanUp
It gives you the opportunity to remove all unreferenced files for the whole vault.
Normally I would create a "scheduled task" (Windows control panel) to run that every week or so, but you have to authenticate as a site admin, so I have to start it manually. But anyway it helps to do it for the whole vault and not having to do it folder by folder.
Hope this helps a little bit.
Greez
Johannes
First of all,thank your for your answer.
But when I run the command you give,the error occur as below:
D:\ptc\Windchill>java wt.fv.ReplicaCleanUp
Exception in thread "main" java.lang.NoClassDefFoundError: wt/fv/ReplicaCleanUp
Can your tell me the reasons?
3Q.
It seems that the class wt.fv.ReplicaCleanUp is not available in your Windchill installation.
I found it in our Windchill 9.1 M030 installation. Maybe, your version does not have this class?
