I am part of product manger and still don't get the permission to edit security from actions menu at folder level. Should I be part of some other group as well to be able to do this action?
There are a few things you need to do in order to modify folder or object level permissions (which is known as "Ad-Hoc" permissions).
Now once that is done, you can update the ad-hoc permissions on a folder (and all objects and sub-folders within it, if desired) or a specific object with the following rules (assuming you have "Update" set for the action):
I'd be happy to discuss your overall access configuration in greater detail, if desired - feel free to send me an e-mail.
