I am looking to edit the Display Name and Description of a Document type in 9.1 M060.
PTC TS suggests to use a xml loader. But the Prerequisite for that is to keep the logical identifier as empty before loading.
I am looking to update the database tables instead.
I updated the display name and description for the particular document type in WTTYPEDEFINITIONMASTER.
Still it does not help.
Is there anything pending for the change to reflect at UI level?
This Information will be of great help.
Thanks & regards,
Prabhu
You may need to restart the server after manually updating the db table in order to see the change
Any answer to this? How do you change the Display Name of Object Type?
Prabhu,
Are you talking about CS19123? This has worked for me without problem. Attached is one of the files I've used.
Hi Ben,
Thanks for the reply.
But, I have tried through the loader. The Prerequisite being that the logical identifier field needs to be made blank before initiating the load.
The Problem I was facing with this is that all our legacy documents of that particular type get changed to the default document type.
I wanted to avoid this scenario as it inflicts upon the existing documents.
That is why I was looking for some workaround at the backend.
Thanks & regards,
Prabhu Vakel
I don't understand this portion of your comment:
I have soft types of WTDocument. Some have Logicial Identifier. Some do not.
Is the 3rd bullet point the issue you are having? If yes, then can you add a new unique value in the <csvlogicalIdentifier> tag?
Good day Prabhu,
I am checking in regarding the suggestions made by Lori and Ben, were you able to solove your issue?
Best,
Toby
