How to find instances from familytable via SQL?
Hi @MN_9999219
Generally i think information is stored in a EPMSepFamilyTable
Here is example how to get filevault of familytable so if you extract the EPMSepFamilyTable you can build our select to get family instances.
select substring(convert(varchar(100),convert(varbinary(100), FVI.uniqueSequenceNumber, 256),2),3,14) vaultFileName,apData.idA3A5 as FvItem, apData.fileName ,MSTR.documentNumber, EPM.versionIdA2versionInfo,EPM.iterationIdA2iterationInfo, MSTR.CADName from wcuser.EPMDocument EPM
inner join wcuser.EPMDocumentMaster MSTR
on MSTR.idA2A2 = EPM.idA3masterReference
inner join wcuser.EPMContainedIn CONTIN
on EPM.idA2A2 = CONTIN.idA3A5
inner join wcuser.EPMSepFamilyTable FT
on FT.idA2A2 = CONTIN.idA3B5
inner join wcuser.HolderToContent CONTENT
on CONTENT.idA3A5 = FT.idA2A2
inner join wcuser.ApplicationData apData
ON apData.idA2A2 = CONTENT.idA3B5
inner join wcuser.FvItem FVI
on apData.idA3A5 = FVI.idA2A2
where MSTR.CADName='m5x25.prt'
PetrH
Hi @MN_9999219
Better example for MS SQL search by CAD Model name. You can use any instance or generic cadname
select mstr.CADName,* from wcuser.EPMDocument epm
inner join wcuser.EPMDocumentMaster mstr on mstr.idA2A2=epm.idA3masterReference
inner join wcuser.EPMContainedIn contain on contain.idA3A5=epm.idA2A2
inner join wcuser.EPMSepFamilyTable sep on contain.idA3B5=sep.idA2A2
where sep.idA3masterReference in (select sep.idA3masterReference from wcuser.EPMDocument epm
where (mstr.CADName='m5x15.prt'))
m5x15.prt is CAD fila name
PetrH
How do I get the data for entire Familytable rather than any instance or a cadname?
I don't understand your question
What kind of data?
How do you identify family table? number name filename what ever so use it.
by select you can define exactly what you want.
Use specific column and table identification instead of "*" asterix
PetrH
aditional information
cadname is filename in windchill
and only generic family table has primary content with filename so if you use filename of generic family table as the CADName you will get "all" information about family table with instances.
PetrH
Also an another thread maybe help you.
PetrH
You can also import a query builder report and look at the SQL query generated from there
Hi @Marco_Tosin
You right.
The shown sql query from the query builder is not so reader friendly but usable 😄
PetrH
