How to get CAD Structure
adev
Hello friends,
I am looking for a query which can return me the CAD structure in windchill does some body know how we can achieve this. please see the screen shot
BineshKumar1
(To:adev)
SELECT DISTINCT A0B.name ParentName,
                A0B.documentNumber ParentNumber,
                A2B.name ChildName,
                A2B.documentNumber ChildNumber
FROM            EPMDocument A0,
                EPMDocumentMaster A0B,
                EPMDocumentMaster A1,
                EPMDocument A2,
                EPMDocumentMaster A2B,
                EPMMemberLink A3
WHERE           (A0.idA3masterReference=A0B.idA2A2)
AND             (A2.idA3masterReference=A2B.idA2A2)
AND              ((A0B.name = 'ER00020039.asm'))
AND             ((A3.idA3B5 = A1.idA2A2)
AND              (A3.idA3A5 = A0.idA2A2)
AND           (A2.idA3masterReference = A1.idA2A2));
Try this. It worked on my system to get level 1 CAD structure.
Thank you
Binesh Kumar
7 REPLIES 7
BineshKumar1
(To:adev)
User epmmemberlink table to connect two epmdocuments. If you are looking for reference documents, use epmreference table
Thank you,
Binesh
Hi Binesh,
I try this but seems like not getting the accurate result
SELECT    dM2.DOCUMENTNUMBER AS ASSEMBLY, M1.DOCUMENTNUMBER AS COMPONENT
FROM      EPMDOCUMENT, EPMDOCUMENTMASTER M2, EPMMEMBERLINK, EPMDOCUMENTMASTER M1
WHERE       EPMMEMBERLINK.IDA3B5 = M1.IDA2A2
                   and M2.DOCUMENTNUMBER = 'W10805805_CP01.PRT'
                   and EPMDOCUMENT.IDA3MASTERREFERENCE = M1.IDA2A2
GROUP BY  M2.DOCUMENTNUMBER, M1.DOCUMENTNUMBER
order by  M2.DOCUMENTNUMBER, M1.DOCUMENTNUMBER;
BineshKumar1
(To:adev)
Could you try this one?
EPMDocument A0,EPMDocumentMaster A1,EPMDocument A2,EPMDocumentMaster A3,PDMLinkProduct A4,EPMMemberLink A5
A0.idA3masterReference = A1.idA2A2
A2.idA3masterReference = A3.idA2A2
A5.idA3B5 = A1.idA2A2
A5.idA3A5 = A2.idA2A2
Thank you
Binesh Kumar
nup it did not workout gives null values
BineshKumar1
(To:adev)
                A2B.name ChildName,
                EPMDocument A2,
                EPMMemberLink A3
Thank you
Binesh Kumar
It worked Thank ou so much Binesh
tanvisharma13
6-Contributor
(To:adev)
I am looking to do the same programatically.
Can anyone pls suggest relevant API to do the same.
Thanks in Advance..
