Hi All,
I can get change request using this rest service
GET : "/Windchill/servlet/odata/ChangeMgmt/ChangeRequests('OR:wt.change2.WTChangeRequest2:250300')?$expand=AffectedObjects",
but I want to get this OID "OR:wt.change2.WTChangeRequest2:250300" from WTpart which should be navigate.
- Tried with this api but can't get change request object id.
GET : "/Windchill/servlet/odata/ChangeMgmt/Changeables('OR:wt.part.WTPart:262627')?$expand=AffectedByObjects"
Can anybody help to get this change object, is there any Windchill rest API?
Thanks.
is anyone knows the solution?
What version of Windchill and REST API are you using?
Did you get your examples from this article?
https://www.ptc.com/en/support/article/CS300711
I'd suggest opening up a Customization case, to get assistance, and maybe they can confirm if that article is still up-to-date or not, as there was talk about this being available in later versions of REST API?
Mike
Thanks @MichaelChatel
But We can not get change notice object details from wt part there is no rest api available in version wrs1.5.
