How to get change object from WTPart using rest service?
mohitenw
Hi All,
I can get change request using this rest service
GET : "/Windchill/servlet/odata/ChangeMgmt/ChangeRequests('OR:wt.change2.WTChangeRequest2:250300')?$expand=AffectedObjects",
but I want to get this OID "OR:wt.change2.WTChangeRequest2:250300" from WTpart which should be navigate.
- Tried with this api but can't get change request object id.
GET : "/Windchill/servlet/odata/ChangeMgmt/Changeables('OR:wt.part.WTPart:262627')?$expand=AffectedByObjects"
Can anybody help to get this change object, is there any Windchill rest API?
Thanks.
3 REPLIES 3
mohitenw
(To:mohitenw)
is anyone knows the solution?
What version of Windchill and REST API are you using?
Did you get your examples from this article?
https://www.ptc.com/en/support/article/CS300711
I'd suggest opening up a Customization case, to get assistance, and maybe they can confirm if that article is still up-to-date or not, as there was talk about this being available in later versions of REST API?
Mike
Thanks @MichaelChatel
But We can not get change notice object details from wt part there is no rest api available in version wrs1.5.
