How to get license usage count both daily & named
MS_13073454
2-Explorer
I am using Windchill PDMLink Release 13.0 and Datecode with CPS 13.0.2.2
Is there a report/qml/sql script to get the list of the licenses consumed both named& daily basis.
Hello MS_13073454,
Did you review CS365764 ?
KR,
Charles.
Hi @cgautier ,
as you probably already know, the challenges a Windchill administrator faces in licence management are many and complex.
Several query builder reports already exist in the user community, and also on the PTC support site, which can be used for the topic under discussion.
What is missing, and what we've ALL been asking for for years, is something that allows for timely monitoring of the use of licences, the users to whom they are assigned, etc.
For example, I already have a report that checks the number of monthly accesses to the system and that I need to understand if a user has been under-using the system for some time and therefore potentially can have his access taken away.
But there is no report to the contrary, i.e. one that can only extract the list of users who are NOT using the system and when was the last time they logged in.
But if a user logs into Windchill and has multiple licenses assigned (e.g., Advanced and Creo Data Management) there is no way to be able to tell if he uses both and how often.
In large companies, and with locations scattered around the world, how can those administering Windchill know if a user who used to be a CAD designer has changed job and therefore only needs the Base or Advanced license and instead no longer uses the one for CAD data management?
If Performance Advisor is enabled for Windchill, weekly or monthly the system collects this information and sends it to PTC, which then posts it on the customer's dashboard.
How is this information extracted and how can the user ID, written in the xml files of data sent to PTC, be linked to an individual (with first and last name) to verify who is accessing, what type of license they are using, and when they are doing so?
Marco
SQL statements?
The license topic is a complex thing.
Our Windchill env is one of the larger systems. Sometimes we run into license problems with Navigate.
We are monitoring the Windchill with several tools like MBeans, SQL and so on.
The license report tool is not the "live monitoring" solution. Does anybody solved something like that?
Live view of used licenses?
See attached screenshots.
HelesicPetr
(To:Marco_Tosin)
Hi @Marco_Tosin
Good idea to ask for this license functionality.
The main point is that information you are asking, is not saved, logged, monitored so you can not get that information in the system for now .
PTC has to add a functionality that store information about license usage on daily time frame and license group.
PetrH.
