Hello @ThorstenMueller,
With reference to topic
I was looking for a similar solution. I have gone through this article, what is the endpoint to get representation?
representationJSON = Things["ptc-windchill-OData-connector"].getRepresentiation({ ID: defaultRepresentationdId /* STRING */ });
Didn't find the getRepresentation in the OData Connector? What's the OData endpoint to get representations?
When I try to fetch representations, it returns me creoview URL, something starts with creoview://?wcparams=
eeYjsdbbDJkada... but I'm looking for the actual pvz file url.
How to get the PVZ file url?
Thank you in advance!
There is a WRS Services Endpoint called getPVZ, as mentioned in the original post. It's in the Visualization domain.
Depending on the configuration of you Connector you could directly call (if the domain is configured in your configuration) or you could try and use a call like parts or caddocuments and use odata Navigation to navigate to the representation. And getPVZ.
Kind regards
Thorsten
Hello @AK_10385731,
It looks like you have a response on your topic. If it helped you solve your question please mark the reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
