Our requirement is integrating Polarian with Windchill through Windchill moduler. We need to import EBSPlmAdapter.war file using windchill extension center. Can you help and guide how to do this.
Similar question - "I Need to integrate the Windchill with Polarion Integration for Windchill": https://community.ptc.com/t5/Windchill/I-Need-to-integrate-the-Windchill-with-Polarion-Integration-for/td-p/900237
h
It wouldn't hurt to write two lines of commentary when attaching some files, otherwise you can't tell what a user is doing.
This is the email that comes in from the community.
