Thanks to all that replied. Everything seems to of worked. I've tested
WF4.0 M120 with Intralink 3.4 M060 with Windows 7 Enterprise 64bit. Tested
as in checked out a 100+ part assembly & opened it, did some editing, then
closed without saving. I also checked out a test prt/drw, upped the rev
level, did some changes, then checked it back in. No apparent issues but
more testing, as in a few days of steady work, is required. Summary
below.
Pro seems to love the Solid State Drives drives. The 100+ part
assembly opens quite fast. However the drives themselves, 2-0 gig OCZ
Vertex drives were difficult to set up, as in flashing the correct firmware,
setting up the RAID 0, creating an aligned partition. Once Win7 saw
that partition & I selected it for the install & hit the go button, Windows
installed very quickly, I was at the desktop in 9 mins.
Summary:
"We ran 32-bit client on 64-bit OS (Vista) for almost a year. We only had
one issue. When users of Vista would check in an object to commonspace.
The timestamp would be off by 6 hours. The timestamp was correct in the
database. Only saw the issue with Vista. We ran our Intralink client on
32-bit Windows XP and Vista. "
