Intralink 3.4 M060 64bit?
JOES
Today I located a 64bit VPN client that works. This weekend I am loading
up two Solid State hard drives in a RAID 0 config with Windows 7 on my home
machine. I commonly work remotely & am hoping to enjoy a 64 bit
environment with SSD drives.
I've searched previous posts & I know this has been discussed before, but
here goes again...
Is anyone running Intralink 3.4 (m060) in a 64bit O.S.? I've reaching here
but how about Windows 7 64bit?
How about Wildfire 4.0 in Win7 64bit?
Thanks & have a great weekend,
Joe S.
JOES
(To:JOES)
Thanks to all that replied. Everything seems to of worked. I've tested
WF4.0 M120 with Intralink 3.4 M060 with Windows 7 Enterprise 64bit. Tested
as in checked out a 100+ part assembly & opened it, did some editing, then
closed without saving. I also checked out a test prt/drw, upped the rev
level, did some changes, then checked it back in. No apparent issues but
more testing, as in a few days of steady work, is required. Summary
below.
Pro seems to love the Solid State Drives drives. The 100+ part
assembly opens quite fast. However the drives themselves, 2-0 gig OCZ
Vertex drives were difficult to set up, as in flashing the correct firmware,
setting up the RAID 0, creating an aligned partition. Once Win7 saw
that partition & I selected it for the install & hit the go button, Windows
installed very quickly, I was at the desktop in 9 mins.
Summary:
"We ran 32-bit client on 64-bit OS (Vista) for almost a year. We only had
one issue. When users of Vista would check in an object to commonspace.
The timestamp would be off by 6 hours. The timestamp was correct in the
database. Only saw the issue with Vista. We ran our Intralink client on
32-bit Windows XP and Vista. "
