Is it possible to run Intralink 3.4 with 64 bit Windows 7? If so, what has to be done to make it work? Since Intralink spawns Pro/E is there any problem running Intralink 3.4 in 32 bit mode with 64 bit Pro/E?
William,
I will be nice today, but in the future, I suggest you try using the search function. This is a common question that comes up about once a month and there is a plethora of information on the list. Below are a few links I recommend you look at:
http://portal.ptcuser.org/p/fo/st/topic=3&post=92214#p92214
http://portal.ptcuser.org/p/fo/st/topic=19&post=64869#p64869
http://portal.ptcuser.org/p/fo/st/topic=19&post=80221#p80221
http://portal.ptcuser.org/p/fo/st/topic=12&post=91208#p91208
http://portal.ptcuser.org/p/fo/st/topic=12&post=97903#p97903
In Reply to William Bowling:
