Hello everyone.
we are preparing for an intralink migration and we are wondering if we can select the ProE files to be migrated.
I understand that if a part is used in a assembly I want to migrate I have no choice but to migrate it too. Even if the part is only used in an older iteration of the assembly.
This concerns group of parts which have no dependencies with what we want to migrated.
Any help thank you
Best regards
The Pro/INTRALINK Migrator tool migrates everythingaccording to object type (file extension). You can exclude some but not all files of an object type by deleting them from Pro/INTRALINK prior to migration. In your migration clone, delete the offending objects and then run the migrator.
Kind Regards
