We have around 100 released drawings and 45 assembly parts which needs to send supplier.
Is any possible method we can export drawings as PDF and EBOM at one shot from windchill?
Appreciate your help.
Thank you
Selva
If you have PDMLink use Packages functionality with Managed collections.
Rahul
Thank you Rahul, We dont have PDM link.
Without customization it would be a manual process. You could go to the structure page for wtpart if you use them, show the columns you need and export the BOM to a file. Then show CAD Docs, select all drawings, copy to Windchill clipboard and print all to pdf from the clipboard. There's a lot of steps without implementing some customization in your release workflow to take care of it automatically. I've successfully implemented customization to export attribute, BOM and drawing files in the past.
Hi Darrell,
Copy to clip board and print PDF option working good for me. Thank you so much!
I can able to export single part EBOM from WT part structure.Could not find any tools for multiple parts ebom export.
Selva
From the structure page, when I select export, I get all four items structured under it in the exported file.
Windchill 10.2
Thank you Darrell.
We would like to export multiple parts EBOM, Not from single part structure.
Example, Search multiple parts and get the list of WT Assy parts from the resulting field. We would like to export the list of resulting WT parts EBOM as PDF or EXCEL format.
Selva
