8-Gravel
Is it possible to automatically recompute LDAP groups on an hourly basis or multiple times a day?
I am using Windchill PDMLink Release 12.0 and Datecode with CPS 12.0.2.15
We would like to know if it is possible to automatically recompute groups multiple times a day from a Third party LDAP directory. Currently we looked at this article,
https://www.ptc.com/en/support/article/CS29278?source=search,
which shows that groups are recomputed once per day automatically if that property is set.
I also found this article https://support.ptc.com/help/windchill/wc111_hc/whc_en/index.html?_gl=1*47qgm7*_ga*MTE2NTk3MDExOS4xNzA2ODA1MjQ5*_ga_CBN5QVB9VJ*MTcwNzQyOTk3My4xMi4xLjE3MDc0MzA0ODUuMC4wLjA.#page/Windchill_Help_Center/queuemgmtChp_OutBoxBackgroundQueue_CtScheduleQueue.html.
d_grahamAnswer
18-Opal
Sounds like a job for Scheduling Queue entry.
Very doable. I've done it plenty of times for customers that need whatever to happen at prescribed intervals.
In your case, whatever is recomputing your groups.
You mentioned trying to stay OOTB.  You're not going to get there OOTB.
If you need the groups to be recomputed for the sake of workflows, that too can be automated to be immediate rather than waiting 4 hours.
Yes it is possible to re-compute groups multiple times in a day.
This is language independent but you can refer below article as starting point.
https://myjeeva.com/querying-active-directory-using-java.html
Once you have report generated multiple times in a day, you can have workflow processing that report.
Ajit
8-Gravel
Thank you Ajit. Currently I am trying to stay as close to possible to OOTB capabilities. Right now the groups in PDMLink only recompute once per day per this property:
  • wt.inf.team.refreshGroupsDailyQueueTime=12:30:PM
Is there a similar property that can be set to do this multiple times a day or would we need to customize it per your recomendation?
HelesicPetr
Hi @AM_10644680
Iam sure if the property existed it would be in the article CS29278
PetrH
jbailey
18-Opal
Oh boy... dare I say someone wants SCIM in Windchill? I have had a few discussions with PTC's security folks about improving modernizing Windchill's Authentication / Authorization to better manage user's access.
I suggested a working group that could cover SAML, Oauth, provisioning, ACL's etc... Hasn't gone very far yet though.
8-Gravel
OAuth would be nice :). We need to get authentication updated in Windchill.
jbailey
18-Opal
Windchill does support Oauth, SAML etc, but mainly for authentication and whole-system authorization (which relies on ACL's etc).
Would be nice to send additional attributes (SAML) or Claims (Oauth) and let Windchill make some advanced authN/authZ decisions - hence my suggestion to PTC of a working group 🙂
