Pro/I end of life
  • February 27, 2024
  • 1867 views
We have been told that our access to Pro/I ends this year and is no longer supported. How do I export all our legacy data out of Pro/I so that we can still have access to the data in the future. We have two DB to Save. Thanks for you help with this issue.
What version of Pro/I do you have?
PTC should have a utility to convert Pro/I 8,0 and higher to PDMLink as both are based on Windchill.
You can export all CAD data using CAD tool if you are planning to get rid of pro intra link.
If you are planning to convert to Windchill PLM, the article https://www.ptc.com/en/support/article/CS28170  , https://www.ptc.com/en/support/article/CS74951 will help you.
If you convert to Windchill , I would suggest to upgrade your Windchill to current version.
Thanks. Our Pro/I is just for legacy data, and I haven’t used it in years. Is there a bulletin or procedure for exporting all the data out of Pro/I?
