I would be interested to know if there is an OOTB loader (something like load from File) from PTC to load CREO files into Windchill. We have thousands of Creo Drawings and models outside Windchill which we would like to import into Windchill 10.0 M030.
Simple answer is 'No' - it's actually quite a complex process if you consider you will almost certainly have ghost objects, need to check for duplicates etc., build structures and relationships.
There are some third party tools available, but the ones I have seen all interact with Pro/E anyway. May be worth a look though. Fishbowl have what looks like a good one, but this uses a Pro/E session to open each object and check them in once you have resolved any conflicts.
Personally I have always used 'tools - import' in a workspace, and then slowly work through any conflicts.
Simon Lucas
Hi Amit and Simon,
I was thinking of using import to WS option too but this is a very tedious task when considering the amount of data. We have around 50K/Site of Creo files which I need to move into Windchill and 4 sites.
Hi Randy and Andrew,
Thanks for the lead. 2 questions since you have used the software.
Can this be used to migrate data from Pro/I 3.x to Windchill as well? (Considering that somehow I manage to get the data out of 3.x). Also can it handle large number of objects at one shot or do we have to break the data into small chunks?
Thanks and Regard,
Dinil
Hi Dinil
I notice you mention Pro/I 3.x for the first time - is all your CAD data in Intralink? If so, why not use the existingIntralink migrator tool? We used it with a million CAD files from 14 Intralink 3.x servers 2 years ago...
Edwin
In Reply to Dinil Mohan:
Hi Amit and Simon,
Thanks and Regard,
Dinil
Hi Edwin,
My main intention was to migrate the data from Hard Disk to Windchill but since Randy and Andrew mentioned about the application from Fishbowl, I was curious to know if it can be used to migrate data from Pro/I 3.x as well. We are planning to do a migration from 4 of our Pro/I 3.x servers soon.
Dinil
