MPMLink - Plant visualisation bug
JJ_11071153
6-Contributor
In MPMLink module - When we add another resource (e.g. Skill - Assembler) to the Plant system automatically put his visual representation in random place. When I want to update its position to right location going to Plant object -> Structure -> Update Position -> setting another values, it does not move the object by these coordinates, but copies it to other location. (in tree there is no visible another object but it remains on visualisation tab). -> Windchill 13.0.2.0
Fadel
22-Sapphire III
(To:JJ_11071153)
Open a case with technical support , looks like a issue .
Fede
JJ_11071153
6-Contributor
(To:Fadel)
I tried, but I discovered it as partner company of PTC so I do not have SCN number (as it is only for clients) to make a case.
How can I make a case from it without SCN ?
Fadel
22-Sapphire III
(To:JJ_11071153)
You need support for raising a case , neverless I will try to reproduce later on and raise an SPR .
Fede
HelesicPetr
(To:JJ_11071153)
Hi @JJ_11071153
If you are trying to solve the issue for your customer, use their SCN.
As a PTC support partner you should be able to open it with customer's SCN.
PetrH
We found it as PTC partner in our internal tests, not for our client .
Jaroslaw
