Can anyone give me some direction for mapping Pro/ENGINEER parameters to Windchill attributes?
According to the system administrators guide, the parameter-to-attribute mapping should occur when there is an IBA in Windchill with a name (all uppercase) identical to the name of a designated parameter in a Pro/ENGINEER model file and when there is no entry for the Pro/ENGINEER designated parameter in the iba.properties file.
I have followed this and I am not seeing the mapping in Windchill. What am I missing?
Thank you for your advice,
Dax Williams
