Max Search Results = 50
ScottPearson
3-Newcomer
Hello WC Gurus,
Here's a newbie question for you.
When I search for Users on the Participant Admistration page, my results are limited to 50 results/users. I would like to increase my results to 100 users -- which should sufficient to allow me to list all my users.
From the WC 10.0Basic Admin Guide (Ch.8, p.233), I see that the limit of the search result is controlled by a property named Max Count found in the wt.properties file. The default value is 50.
From Windchill 10.0 Specialized Admin Guide (Ch. 3, p.33), here iswhat I have been trying -- without success --in order to
[Note: The double-quotes are because my Intralink 10.0 is on a Windows SQL server and double-quotes are required per the WC 10.0 Specialized Admin Guide, Ch. 3, p.42, because of the space contained in the property name.]
Since xconfmanger did not find the Max Count property, I tried listing ALL the properties in the wt.properties file by using this command:
windchill properties wt.properties
But that result alsodid not list a property named Max Count.
And FYI,this is how I intend to
QUESTION: Can anybody tell me the exact command syntax for changing my search result limit from the default (50) to a custom value (100)?
Any enlightenment will be greatly appreciated.
Many thanks!
Scott
On 07/13/12 11:21, Scott Pearson wrote:
> Hello WC Gurus,
> From the WC 10.0 Basic Admin Guide (Ch.8, p.233), I see that the limit of the search result is
> From Windchill 10.0 Specialized Admin Guide (Ch. 3, p.33), here is what I have been trying --
> without success -- in order to display the current setting of the property so I can verify its value:
> /xconfmanager -d "Max Count"/
> /[Note: The double-quotes are because my Intralink 10.0 is on a Windows SQL server and
> space contained in the property name.]/
Simply open codebase/wt.properties in your favorite text editor and look at the values.
> /windchill properties wt.properties/
> But that result also did not list a property named Max Count.
> And FYI, this is how I intend to change the value of the property if I can find the darn thing...
> /xconfmanager -s "Max Count"=100/
In Windchill 9.1 to change a property with xconfmanager the syntax would be this:
xconfmanager -s wt.calendar.calculateDefaults=false -t codebase/wt.properties -p
-s PropertyName=NewValue
-t NameOfPropertyFile
-p (to propagate the changes just made)
xconfmanager actually writes to the <windchill install=" dir=">/site.xconf file. Without the -p the
changes just made to the site.xconf file won't actually get propogated to the property files. You
can actually change several values and then propogate the changes like this:
xconfmanager -s Property1=Value1 -t codebase/wt.properties
xconfmanager -s Property2=Value2 -t codebase/wt.properties
xconfmanager -s Property3=Value3 -t codebase/wt.properties
xconfmanager -p
This will speed up the process a little because the actual propogation sometimes takes a little bit.
> /QUESTION: *Can anybody tell me the exact command syntax for changing my search result limit from
> the default (50) to a custom value (100)?*/
> Many thanks!
> Scott
> -----End Original Message-----
Randy Jones
Systems Administrator
Great Plains Mfg., Inc.
1525 E North St
PO Box 5060
Salina, KS USA 67401
email: -
Phone: 785-823-3276
Fax: 785-667-2695
