I am trying to install Oracle 19c for Windchill 12.0.2.
I had it installed once on this server, but wiped it out to fix an error with the upgrade process. Now Oracle will not install properly. When I do the install, the setup program makes changes to the files in the folder that I am installing from even though I tell the program to install Oracle to e:\Oracle19c. The install files are in my c:\users home folder. I do not get a DB_Home created, so the PTC configuration for Oracle will not run. I have deleted all references to Oracle in the registry before each install try.
Using the e:\Oracle19c\Oracle19cSetup folder for Oracle_Home allowed the PSI to complete.
Oracle 19 setup is different of 12.
My Steps:
I think it is weird that the installation modifies files in the install folder, but I did it and now have the following structure:
e:\Oracle19c\Oracle19cSetup - Original installation files
e:\Oracle19c\Oracle_Base - Added by the install
However, there is no dbhome directory created like with Oracle 12c that the Windchill setup program recognizes as a folder for dbhome.
On my Windchill 11.1 system, dbhome is: E:\Oracle12cR2\product\12.2.0\dbhome_1
What else is different with the Oracle 19c installation to make it work?
Is Oracle 18 like Oracle 12 or Oracle 19? That is an alternative for Windchill 12.
I encountered the same problem when installing Oracle19C, I choose "Set software only" just like
installing Oracle12c.But after installation,there is no D:\Oracle19c\product\19.0.0\dbhome_1.
Have you come to a conclusion at last?
That is correct.
In Oracle 19c, the DBhome for Windchill is your initial installed folder.
Copy your Oracle 19c installation disk to d:\Oracle19c
Run the setup program and set your install to d:\Oracle19c_base
(You can put them in a single d:\Oracle and then the 2 sub-folders)
When you run the PSI, your Oracle home is d:\Oracle19c
The problem has been solved.
Thank you!
I performed the same steps, however there are no services installed,
After installation, I tried to login like sqlplus / as sysdba, it is not working.
Can someone please guide ?
