Organise new and modified products
dgarcia
Hello all
We would like to have a team of designers for new products and another one for modifications of those products once they are mature. Change Management responsibilities would also be different.
I see 2 possibilities:
  1. One context, everybody has access to everything
    • Pro: easy to configure
    • Con: everybody has access to areas they should not
    • Con: Change Management tasks sent to everybody and they have to decide if they have to act or not
  2. Two contexts. Move mature objects from one context to the other
    • Pro: correct permission to modify
    • Pro: correct Change Management roles
    • Con: manual work to move thing from one context to the other
What do you think?
STEVEG
(To:dgarcia)
Having 2 context is more work.  We have only 1 context no matter how old the product is.  You can have different rights.  Not everyone will have access if you don't want them to.
MikeLockwood
22-Sapphire I
(To:dgarcia)
Ideally, manage this by state, so that there is no need to consider contexts or moving.
If for example, you use numbered Revisions for prototype / development work, and letters for production, then the following major benefits result:
- Allow all users to Revise at the state used for numbered Revision
- Allow only the users who are authorized to work on production data to Revise from the state used for lettered Revisions.
A simple 2-dimensional grid-type diagram helps greatly on this, with the axes of the diagram being state across the bottom and Revisions vertically, with arrows showing the transitions.  Note: All the PTC diagrams on this are one-dimension, including all the training.
