Overdue Notification email for the change object
BikrantS
8-Gravel
I want to setup automatic email notification to the Creator of the change object when a it becomes overdue. I want utilize an attribute Need_Date which we are filling during the chanage object creation.
You need to set it up in the WorkFlow using a timer robot that counts down and sends notification to the "Creator" of the Change Object. Please look in to OOTB need date , for eg. for change Task objects ,this attribute is already there and system sends notification to the task assignee using the same timer robot, Study it and implement in your object.
Cheers
Hari
Hello @Hari_Vara ,
Thanks for the hint.
Please could you also share some support article links if you have or any additional info.
Really appreciate your help.
Bikrant
avillanueva
23-Emerald I
(To:BikrantS)
Hi @BikrantS,
Anurag
Hi @anursingh ,
Thanks for reaching out.
I am still trying to figure out a solution for this requirement.
Bikrant
