The community will undergo maintenance on October 16th at 10:00 PM PDT and will be unavailable for up to one hour.
PDMLink/ProjectLink Uniqueness with Multiple CAD Migration/Integration Solution
patrick.chin1
The PDF attached makes Windchill 100% compatible to Pro/E with other CAD tools. There are additional steps required to remove the redundant WGM API code to check file uniqueness.
For multiple Pro/I migrations, there is no need for data cleansing. It guarantees 100% success in migrations and data mapping. It is downward and upward compatible because it is based on the foundation of windchill.
I can explain this if you need it.
Here is an update if you have a current productionized system with private projects which admins cannot search via the UI to rename/renumber.
