If you haven't already discovered, all the PTC Live 2014 presentations are now ready to download.
http://portal.ptcuser.org/p/do/sc/catid=69
Marco
Hi David,
thanks for sharing your presentation, you did a very good job.
I read both the presentation with notes and the PDF file and I see your precious job with the notes in ppt.
I set timeout at the minimum and the number of licenses in use has decreased a lot.
I have also tried many times to use CADminTools from Edwin but it never works.
Probably I've done something wrong even if help file seems to be simple.
Hi David,
using your presentation I've done a lot of work to maximize use of our Creo licenses.
To track better also which user is using a specific license I have a question for you.
Your Perl script catch the result of ptcstatus.bat command, extracting and manipulating columns 1 (name of license) and 2 (quantity in use).
I have made some change of your script to track all kind of licenses we have bought and, with no knowledge of Perl language, I completed my job.
Question is: how can I extract from ptcstatus.bat also lines with username@pcname in Perl?
TIA
Marco
