I am using Windchill PDMLink Release 13.0 and Datecode with CPS 13.0.2.6
Same issue occur also in WC 13.1.x.x
Windchill is installed from scratch with just demo's data loaded.
Windchill fail to generate parts list.
Window error pop when select "generate parts list" with message :
ATTENTION: Generation of Parts Lists failed
Check the method server log for details.
Error in method server log file :
2025-07-23 14:26:22,421 ERROR [ajp-nio-127.0.0.1-8010-exec-4] com.ptc.arbortext.windchill.partlist.StandardPartListService demo - Unable to load attribute iterationInfo.state: Unable to get value of attribute WCTYPE|com.ptc.arbortext.windchill.partlist.PartList~MBA|iterationInfo.state from com.ptc.arbortext.windchill.partlist.PartList:com.ptc.arbortext.windchill.partlist.PartList!
Which report were you using to generate parts list? Screen shots?
Hi avillanueva,
Right click on parts list in top part on structure panel then "generate parts list" :
Result :
I am not seeing that action in my install. I see in the logs it refers to arbortext. Does anyone know if this action is related to a special module added to Windchill? Would you mind sharing what modules you have installed?
This action is related with service parts module :
These modules must be installed in order to use these features :
