I was unable to create a custom loadfromfile for non-modeled attributes. I had to use info-engine to populate the soft type attributes we added. Here is apiece for illustrationif you want to use an info-engine task. You can read the part/values in with Java from a file
<ie:webject name="CheckOut-Objects" type="OBJ">
<ie:param name="INSTANCE"" data="IE_Adapter_Service_Name"/">
<ie:param name="OBJECT_REF" data="$(gPart[0]obid[0])"/">
<ie:param name="GROUP_OUT" data="gItem"/">
</ie:webject>
<ie:webject name="Update-Objects" type="OBJ">
<ie:param name="OBJECT_REF" data="$(gItem[0]wt.part.WTPart.obid[0])"/">
<ie:param name="GROUP_OUT" data="gOut"/">
</ie:webject>
<ie:webject name="CheckIn-Objects" type="OBJ">
<ie:param name="GROUP_OUT" data="gCheckedIn"/">
</ie:webject>
Glen Herman
Sr Application Developer
Engineering And Technology
Trane Residential Systems
6200 Troup Hwy
Tyler, Texas, 75701
