PDMLink M050 MethodSever Freezing Up
We recently migrated from PDMLink 8.0 M040 to a VM, 64-bit server with 8G of memory. After some back and forth with PTC, we seem to have all of the memorym properties et and are even running a backgound MS to handle the workflow tasks. Our problem now is the MS just seems to stop with no true errors displaying, causing the ServerMnager to kick off another MS(and background MS). The only error we do see occurring at the time of the freeze is from the SM log:
ClientNotifForwarder-3: ERROR : wt.jmx.notif.methodServer.stop - Time=2010-08-24 14:29:43.763 -0500, Name=MethodServerStopNotifier, SourceObjectName=com.ptc:wt.processGroup=MethodServers, class=class javax.management.Notification, type=wt.manager.jmx.MethodServerMProxyMBean.methodServer.jmxConnectionFailed, userData=[displayName=MethodServer.6440,jmxConnectionFailed=true,jvmId=6440,name=MethodServer,remoteJmxUrl=,startDate=2010-08-24 14:08:22.704 -0500], message=JMX connection to method server 'MethodServer.6440' failed., JVM Name=14776@sschawking
Tue 8/24/10 14:29:44: MethodServerMonitor: ERROR : wt.server.manager.startup - Unable to ping MethodServer
Tue 8/24/10 14:29:45: MethodServerMonitor: ERROR : wt.jmx.notif.methodServer.stop - Time=2010-08-24 14:29:45.775 -0500, Name=MethodServerStopNotifier, SourceObjectName=com.ptc:wt.processGroup=MethodServers, class=class javax.management.Notification, type=wt.manager.jmx.MethodServerMProxyMBean.methodServer.removed, userData=[displayName=MethodServer.6440,jmxConnectionFailed=true,jvmId=6440,name=MethodServer,remoteJmxUrl=,startDate=2010-08-24 14:08:22.704 -0500], message=Method server 'MethodServer.6440' removed., JVM Name=14776@sschawking
Tue 8/24/10 14:29:45: MethodServerMonitor: ERROR : wt.manager.ServerTable - Dead MethodServer reported; reported exception: java.rmi.ConnectException: Connection refused to host: sschawking.ndc.nasa.gov; nested exception is:
Tue 8/24/10 14:29:45: MethodServerMonitor: java.net.ConnectException: Connection refused:
As alawys, just wondering if anyone has experienced this and might have some advice. Thanks and Geaux Saints! Who Dat!
Send lawyers, guns, and money...the sh!t has hit the fan!
