I am unfamiliar with this feature and where it is. Can you send screen shots or describe more?
It is inside the probatch file.
Hi @GM_11078588
is your Creo session registered to the Windchill?
CS424934 - Unable to register Windchill server when using Distributed Pro/batch in Creo Parametric
PetrH
Hi @GM_11078588,
Anurag
Hi @GM_11078588
I guess that you need to be in a right group that allows this feature. It is not available if the admin is not in specific user group.
PetrH
Hi any update on the solution?
