Hello everyone!
There are 2 machines:
1) windchill server
2) worker server
Windchill version: 12.0.2.8
Creo View Adapter: 10.0
I'm trying to start worker, but always get the problem "Problem creating directory <directory_path>. Do not have write access"
I've tried 2 ways: ftp and windows shared folder, no one of them works properly and responses the same porblem
There is no any access restriction to this folder, so I use like "All users = Full Control".
Moreover I can without any problem connect from windchill machine to worker machine and manually create/delete files in this folder using Explorer to do this with Shared Folder and using cmd to do it with ftp.
Maybe someone has already fixed it? If you need more information please let met know
Here's log from Worker test:
2023-11-16 11:57:25: Starting worker test
2023-11-16 11:57:25: Added request to INVENTOR queue
2023-11-16 11:57:26: Test job for Worker: <HOST_NAME>-INVENTOR:1
2023-11-16 11:57:26: Processing work order
2023-11-16 11:57:26: Deleting all files from <directory_path>\w1i1j2
2023-11-16 11:57:26: Successfully deleted all files
2023-11-16 11:57:26: Creating directory <directory_path>\w1i1j2
2023-11-16 11:57:26: Problem creating directory <directory_path>. It already exists as a file
2023-11-16 11:57:26: Problem creating directory <directory_path>. Do not have write access
2023-11-16 11:57:26: Worker test returned an error message
2023-11-16 11:57:26: Unable to submit job to worker
Articles:
Articles:
